boiler does not kick,s on despite pilot is on and thermostat up
i do have W Mclain force hot water system boiler in the house.pilot is on, thermostat all way up and i do have 120V on T1&T2 in relay but nothing happens
Esta é uma boa pergunta?
Pressure Switch
The pressure switch closes when the proper airflow is achieved, signaling the control board to continue the ignition process. If the pressure switch is defective, the ignition process will stall, and the water heater will not light.
Thermocouple
The thermocouple detects the pilot flame. If the thermocouple does not detect a flame, the ignition process will stall, and the burner will not light
Esta resposta foi útil?
this is force hot water system.pilot is on so thermocouple is ok
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 50
