Ir para o conteúdo principal
Torn internal connection cable
My ear piece speaker stopped working. So I ordered a new one from amazon and opened up my phone to replace it. During the opening, the guitar pick sliced through the two connection cables internally on the left hand side of the phone. Regardless, I carried on and fitted the speaker and put the phone back together. I will take it to a phone repairer tomorrow to get it fixed.
My question is; what are these two cables called and are they expensive to replace?
Thanks you.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@sarahsyers help us to help you. Post some pictures of what cables you cut with your QUESTION Adicionar imagens a uma pergunta já existente
por
I can’t. As my phone is broken. But It is the black ribbon cable set halfway down the right hand side, that connect the base and the screen sections, when you open up the phone. both are partly severed.
por
Adicionar um comentário
2 respostas
Solução escolhida
They’re not repairable, they are the display and home button cables, both _parts_ of the display assembly. The good news is that a screen replacement isn’t such an expensive repair.
Esta resposta foi útil?
Pontuação 3
Is it the top or the bottom I have a 7 plus also
Pontuação 0
4 comentários:
por
That is for the lcd and the home button.
por
Are these two cables a replaceable part please?
por
The screen is replaceable the home button is probrally fine
por
Adicionar a sua resposta
Sarah Syers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Ao todo: 829
