Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
Poor GPS quality after screen replacement
I have recently replace the display of an iPhone X after it receive an hammer, now the GPS present issue, is really inaccurate and doesn’t work well with navigator apps but a few times it works fine.
I would like to know if it cause by the screen replacement or by something else and possible solution
Thk
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
Was this little gold piece placed back in step 22 of this guide?
Substituição da tela do iPhone X
Esta resposta foi útil?
Pontuação 2
3 comentários:
Yes, I'm gonna check if I place it in the correct position place as show in the pictures, in case is not in the correct place can that be the issue ?
por
Not 100% sure but those grounding pins do have an affect on the antenna strength as the housing is essentially an antenna.
por
Well I check and the little gold piece was in the right place, and still having issue i try with GPS status to check the accuracy and while my iPhone XS can have a 5mt accuracy the iphone X doesn't go lower then 32mt.
Also i try reset location and network ecc. like in some guides
por
i have the same issue…..
thought about replacing the antenna but…. is the WiFi antenna is the one i should replace? (its at the bottom of the phone and has nothing to do with the screen replacement procedure…)
i cant find any GPS antenna….
Pontuação 0
1 comentário:
I have the same problem after doing a screen replacement - GPS worked fine before screen cracked from being dropped. I did the screen replace and now no GPS. I don't think replacing the wifi antenna will help GPS reception. I called an ifix store and they said GPS is in the motherboard. Going to try factory reset next.
por
Adicionar a sua resposta
Daniele Zamboni será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 5,967
