Ir para o conteúdo principal
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Perguntas Visualizar todos
error 9 , error 40
Hi , i have an ipad 4 which suddenly showed the apple logo during normal use . when i tried to update / restore i got error 9 , i tried a new lightning port , new battery , tried a restore with reiboot pro . also tried another pc and a macbook for the restore …
I removed the board and used naviplus pro to read the nand chip , seems ok , i also repaired the nand with naviplus and tried to restore again , now i get error 40 . , i’m thinking now may be cpu , is there a test to confirm this ?
..here is a link to the itunes restore log
https://www.dropbox.com/s/3al0q9okudom8e...
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I,m not sure if i’ve made progress with this or not , i gave the nand chip some heat , plugged it into the naviplus again and noticed the model no R/M . box was blank , i filled this in and it restored ok . now i have activation error !!  ,,  its a wifi only model and i tried the restore with pc and a macbook , same result ,...
por
Adicionar um comentário
1 resposta
all the way at the bottom of the restore log it says this
[19:07:11.7430] Depth:2 Code:40 Error:storage device did not become available
maybe it is your storage device that is bad, and not a cpu.
Esta resposta foi útil?
Pontuação 0
1 comentário:
so that would suggest the nand chip , i thought that as the naviplus machine was able to read and write to it ok that would rule that out ..
por
Adicionar a sua resposta
markparnell1972 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 187
