Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
2010 MacBook Pro system report says no battery present
when i unplug my 2010 macbook pro it will turn off, i have done an smc reset and pram reset, it doesnt show the battery icon at the top of the screen either. I have searched around the internet for any fixes and none helped.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
On the left side of the uppercase body is a battery checker how many LED’s do you see lighting up?
Esta resposta foi útil?
Pontuação 1
6 comentários:
no LED's light up
por
Then your battery is not charging or is bad. What does the MagSafe LED show you Green or Amber when you plug it in?
por
the magsafe is always green
por
and i added a picture of coconut battery
por
You need a new battery ;-{ The microController within the battery is not working and as such the battery can't get charged.
Here's the needed battery MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Battery and here's the guide Substituição da bateria do MacBook Pro 13" Monobloco de meados de 2010
por
Exibir mais 1 comentário
Pergunta mais útil
Please use a better tool (free) Coconut Battery and post your results.
https://coconut-flavour.com/coconutbatte...
Pontuação 1
2 comentários:
okay i will download the program and post the results when i get home
por
the picture of coconut battery is up on the question
por
Adicionar a sua resposta
Vipaha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 54
