Ir para o conteúdo principal
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
Can you add a 2nd HDD to the $799 Mac Mini?
I've looked at the teardown and I must ask if anyone knows if you can add a 2nd HD to the $799 Mac Mini. The reason I ask is because you cannot get the AMD Radeon HD 6630M Graphics card and a second hard drive.
If I buy a $799 Mac Mini and choose to add a second HDD will there still be room or does the Radeon HD 6630M card get in the way?
I want the server version, but you have no choice on graphics cards. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I can confirm I was able to install a 2nd drive in mine just fine. In fact I replaced the stock 500G drive and installed two SAMSUNG Spinpoint M8 HN-M101MBB 1TB 5400 RPM 8MB Cache 2.5" SATA 3.0Gb/s Internal Notebook Hard Drive -Bare Drive from newegg.com.
Esta resposta foi útil?
Pontuação 2
2 comentários:
+ what cabling did you use?
por
I used the cable sold by iFixit.com, and the original Apple cable. I did peel off the black plastic from Apple's drive and transfer it to the new drive. Don't want any shorting.
por
As far as I know there's no definitive answer yet. I guess we're waiting for someone to actually obtain the required cable and successfully fit a second drive in a 2011 mini with Radeon 6630M. It certainly looked like there was room in mine when I fitted my SSD the other day. It had the space under the HD just like in the teardown of the Intel-graphics-only mini. As soon as it's confirmed possible I'll be adding a second drive to mine for Windows.
Pontuação 0
Adicionar a sua resposta
Shane Whitford será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 2,209
