Ir para o conteúdo principal
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
71 Perguntas Visualizar todos
Pixel XL wont turn on, new battery
I replaced my battery a week ago, and now it wont turn on.
I used my phone all week with no issues, but last night i let the phone run out of juice and now it wont turn on, it doesn’t even look like it is charging
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
So I had a local CPR look at the phone, They tried swamping the screen with no luck. The tester indicated that the battery is high speed charging but still not powering on. If i plug the phone into a computer it does recognize the phone is there.
por
Also when plugged into the computer if I hold the power button down on the phone i can make it disconnect and reconnect to the computer but phone still does not look to be on.
por
Adicionar um comentário
1 resposta
hi
your phone doesn’t charge because the battery is to low to begin charging
you need to charge the battery out of your phone to give her some power
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Clifford McDonald será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 117
