Ir para o conteúdo principal
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
78 Perguntas Visualizar todos
I have problem with horn
I have problem with horn in corolla 2003. It work in remote finding on remote lock but it doesn't work on the steering wheel. I checked fuse and all seems fine. Also the clock inside the car shot down few weeks before that. After these issues happened I recently changed the battery nothing changed. Any idea?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
@mazetta this was moved from an answer you left to its own question
por
Adicionar um comentário
1 resposta
There is probably more than one horn and maybe each one operates for a different purpose. As stated above, you can hot wire your horns to test the horns themself, then work your way backwards through the wires, to relays, to additional wires to fuses to your horn connector in the steering wheel. Relays are typically bad, you can swap same type relay from another system for temporary testing, no problem.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Maz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 757
