Bought new charger tablet is not charging
I bought a new charger for my tablet and my tablet still won't charge how can I troubleshoot it to find out what's wrong if it's charging or the tablet
Esta é uma boa pergunta?
Did you check the charging port for damage? Look inside for bent/missing pins. Also plug in the cable and gently push up and down to see if the port itself is loose.
If you need a replacement port, the process will require micro-soldering.
Esta resposta foi útil?
Did you test the old and new charger for power at the plug that goes into the tablet?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 37
