Ir para o conteúdo principal
[P20 Lite] Is the problem with my screen or motherboard?
I was given a phone what had fell down from a high place, if you turn the phone on / or put the charging cable in the phone, the phone vibrates, a flashing red-light occurs at the top of the phone and screen gets some red&blue&green lines running through it.
I’d like to know if the problem is with the screen or the motherboard, is it worth fixing?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @roal ,
it’s a LCD&Digitizer issue. Follow this video to see, how to repair your issue.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks, just put my order in for new LCD & frame.
Cheers mate, hopefully I'll be able to make the repair :)
por
You are welcome, you will fix it! :) Good luck
por
Adicionar a sua resposta
Raul será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Ao todo: 1,703
