Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Planing to upgrade to Catalina but I have Windows (Bootcamp installed)
I am using both Windows (Bootcamp installed 130 GB) and Mojave (370GB) on my SSD drive at the same time (which also my start up disk). I also have internally connected 1 TB SATA hard-disk which I use for storage purposes and I partitioned it using TUXERA NTFS by 315 GB for Windows storage and 685 GB for Mojave storage.
I am now planing to upgrade Mojave to Catalina but I am afraid I might make a mess by doing so. How should I proceed ?
1) First of all, should I upgrade to Catalina ? (I don’t use any 32 bit apps)
2) If I decide to upgrade, Should I back up everything and erase both Windows on my SSD and Windows Partition of SATA hard-disk and devote both of them again to Mojave, and then upgrade Mojave to Catalina?
3) Or Should I just upgrade my system to Catalina as it is?
Any help and answer is much appreciated..
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I have installed the Catalina after backing up my data. Everything is fine except i’m not able to access bootcamp partition in my mac. Windows is booting fine.
Esta resposta foi útil?
Pontuação 0
1 comentário:
So after installing to Catalina; when you press the option key at the start-up, it gives you the option the choose which operating system to start on (as it was the case in Mojave)?
por
Adicionar a sua resposta
Alican será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,359
