Ir para o conteúdo principal
The entry-level version of the Inspiron 15 7000 gaming notebook from June 2017 lacks the higher-end hardware complement of its pricier siblings. The battery life puts many other laptops—gaming or not—to shame.
15 Perguntas Visualizar todos
little bug scrawled in between screen and protective layer!
Some little bug got in between screen and protective layer of my laptop’s display, it was crawling in the screen i though it is was on outside, so i tried to push it from screen, but i cant, because it was inside… the !&&*, and i accidentally pressed on it and it got stuck in screen looking like a black spot, how can i remove this, i can disassemble the screen but how can i remove it from the screen panel???
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Vishal,
RIP BUG … anyway, you have to disassemble your laptop and then carefully disassemble your display. The display is really brittle, so be careful! You may damage it easily!
Esta resposta foi útil?
Pontuação 0
2 comentários:
I got the service manual from dell, and there is topics for how to remove the screen and display panel, but im not attempting it because im afraid i will damage the screen panel!!
The bug is not that big, i think around 0.1 cm on the screen!! but it still hurts my eyes, i always take good care of laptop since im developer, but this problem i feel hopeless!! i guess i have to take it to service center.
por
You must be very careful. If you don't have any experineces with disassembling, put it into the local service shop. In the other case, proceed with caution :)
por
Adicionar a sua resposta
Vishal Solanki será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 42
