Ir para o conteúdo principal
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
Maximum RAM Upgrade for 1286A
My MacBook Pro 1286A (Late 2008) came installed with 2GB of RAM. It's in need of an update. According to Apple, the max it can handle is 4GB, but I'm reading online that some these can be upgraded to 8GB. If I can go to 8GB, I'd like to.
Your input would be greatly appreciated!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Please give us the last three figures of your serial number for an exact answer on your question.
por
Adicionar um comentário
2 respostas
Solução escolhida
Try using "Mactracker" (http://itunes.apple.com/us/app/mactracke...), it's a free application that'll tell you the maximum amount of ram your Mac will support, along with pretty much everything you need to know about every other Apple product ever made.
Esta resposta foi útil?
Pontuação 1
There is new firmware for the Late 2008 Macbook Pros that allow 8GB of ram to be supported.
Pontuação 1
4 comentários:
you you care to elaborate or give a link on this firmware?
por
Apple released this 2-28-2012.
http://support.apple.com/kb/DL1502
I'm using this on my Late 2008 MBP with 8GB ram and it works great. It doesn't say anything about the ram limit being higher but OWC did testing and it works fine.
por
Mitch, I know about the update, I'm trying to help you become a better answers contributor. What I was trying to get you to do was the work. As a new contributor or an old one, you really need to support an answer. Even the link you gave says nothing about the RAM change. The link you should have given was the one that supports your statement. That's this one: http://blog.macsales.com/9102-secret-fir...
por
Thanks for the link, I didn't know it was there. I was just pointing to the firmware update that the person needed.
por
Adicionar a sua resposta
Jason C será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 1,748
