Ir para o conteúdo principal
Informações de reparo para o Samsung Galaxy J7 Refine, lançado em 2018. Número do modelo: SM-J737PZDEBST.
Incoming doesn't work when WiFi connected.
My phone will not receive incoming calls and texts of I'm connected to WiFi. I've looked through every possible setting in my phone, I refreshed network, I've factory reset my phone. If I restart it, everything will come through and then go back to not getting anything. If I have WiFi off, everything works. I've gotten nowhere with my phone provider, even though contacting them 5 times. I'm at a loss.
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Is your SIM card activated? Do you have wifi calling enabled?
por
Yes it's activated, and I have no idea where that is, I'll look though. All my settings for calls are what set to when I factory reset my phone, so I should be good.
por
The only solution is replacement, S9 or 9+. I recently got the 9+ to replace my J7, which was designed to fail within 18-24 month, for sure.
por
Adicionar um comentário
1 resposta
Go to your dialer (phone icon) hit 3 dots in top right corner. Disable wifi calling then restart. Try receiving a call
Esta resposta foi útil?
Pontuação 0
1 comentário:
There is no such option in that menu, or when I click settings from that menu.
por
Adicionar a sua resposta
asmith298828 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 273
