headlights don't work but bright lights do work
got a 1999 two door tahoe and the headlights do not work, but the bright lights work fine. i tried new bulbs, new fuses and even got a new control switch. what else can i do? and how?
Esta é uma boa pergunta?
9 comentários
Have a 96 Chevy Tahoe.. High Beams work Low Beans Don't.. As I was looking this up the low Beans Turned on? I hope they stay working but if they don't turn on again what would be the Problem? A short? A Relay? Tia..
por Guillermo Beltran
Brightlight works but dim bim not working
por lunga tshazela
I have a 96 Oldsmobile Auroa passeger headliht is out hi beams work perfect. HELP
por Lemitia
I have a 97 chevy tahoe, low beam does not work, but high beam does. I went thru the fuse box under the hood and I don't see any fuse labeled LO HDLP. Pls help,
por johnqv
I have a 1996 Toyota Tacoma with 2.4l engine and extended cab 2x2. Left high beam does not work even with brand new relay. Solution? I also tried new headlight. No highbeam.
por Hannibal
Exibir mais 4 comentários
