Ir para o conteúdo principal
Weak Wifi or poor Signal
This iPhone only sees near WiFi networks. The more far away the router the more poor signal
I have replaced this antenna:
iPhone 6 Plus 5GHz Wi-Fi Antenna
And no differnece
SHould I try with this?
iPhone 6 Plus Wi-Fi/Bluetooth Antenna
Thank you
Update (09/27/2019)
Hi, no antennas have fixed the problem. It seems to be a hardware issue. I will send to my friend’s lab to see if it can be fixed. I will post the results. Thank you
Imagem de iPhone 6 Plus 5GHz Wi-Fi Antenna
Produto
$7.99
Imagem de iPhone 6 Plus Wi-Fi/Bluetooth Antenna
Produto
$14.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
I would like to suggest a cheaper way than replacing a router? But you need jailbreak for this. You can install SignalRefresh Cydia Tweak on your device and boost the signal strength. The tweak is available in Bigboss repository in Cydia apps store. If you feel you need to try this but do not know about jailbreaking will www.cydiacloud.com be useful
Esta resposta foi útil?
Pontuação 1
Hi @macpatagon
Have you tried to update or restore the software? Sometimes weird issues can be caused by third party apps and/or software bugs.
Pontuação 0
Adicionar a sua resposta
Flavio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 64
