Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
PS4 shuts down when connected to Wi-Fi
I moved recently to a brand new flat and it worked like a charm for the past 2 months when I connect it to the internet through Wi-Fi. Now it simply crashes within 10 minutes of connecting it to Wi-Fi. Ethernet remains functional though. The TV screen just goes all of a sudden blank and no light is visible on the actual console when the fault occurs. When I press the power button on the PS4 it beeps but nothing happens (no light also shows up). On the second press it boots into recovery mode and begins to analyze itself. Once it’s done it gives me a warning to turn off the console properly next time before unplugging the AC cord. I tried booting it into safe mode and running all possible options except the options which require the wipe of the hard drive. I reflashed the operating system but nothing helped. The console is a PS4 CUH-1216B model if it helps anybody. Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I figured it out. I suspected that static electricity built up inside the console somehow and I removed the AC cord from the console and pressed and held the power button for 10 seconds to clear out the suspect. I have been using Wi-Fi for 2 hours now and the console remains stable.
Esta resposta foi útil?
Pontuação 0
2 comentários:
But did it really solve your problem permanently?
por
It started to do it again (shut down unexpectedly). I repeated the above mentioned procedure again and so far so good (didn't see the problem reoccur for 5 months now). Perhaps there is some electromagnetic interference from a nearby electronic device.
por
Adicionar a sua resposta
Luka Pranjić será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 2,838
