Ir para o conteúdo principal
HP released this ergonomic laptop (model number 15-au123cl) in October 2016. It features Windows 10 and a touch screen.
14 Perguntas Visualizar todos
If I wanted to install a thunderbolt port, how would I do so?
I want to remove a USB port and instead install a thunderbolt port with a Thunderbolt chip from HP as well. I wanted to do this from the I/O, and remove the USB 2.0 slot.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
That model laptop already has two USB 3.1 ports according to HP’s web site, which support Thunderbolt 2 speeds via a dongle, as long as the data is only moving one direction.
As far as replacing the USB 2.0 port directly on the system board with a different port, that’s pretty much impossible because the connector from the board to the I/O port is pretty different between USB 2.0 and Thunderbolt 2, and Thunderbolt 2 and 3 also need a controller chip in order to function properly. Also, Thunderbolt runs through PCI lanes and the I/O board is probably not assigned any at all, because USB handles data differently.
Thunderbolt in general is kind of a mess, and unfortunately while it’s useful and fast there really isn’t a way to add it to a laptop that doesn’t already have it without replacing the system board and hoping everything still fits.
Esta resposta foi útil?
Pontuação 2
2 comentários:
But what if I want to change usb-c for thunderbolt 3?
por
You'd need a way to assign PCI lanes to the Thunderbolt controller, which would unfortunately pretty much mean a full motherboard/BIOS redesign. Just not really something you can do, unfortunately, even though the connector is the same. It's that dang controller chip Thunderbolt needs.
por
Adicionar a sua resposta
Tyrell Compton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 29
Duração total: 684
