Ir para o conteúdo principal
Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
288 Perguntas Visualizar todos
Screw of CMOS battery door is threaded.
Help I have no idea what to do I accidentally threaded the screw of the CMOS battery door and I cannot remove it. I also need a replacement as I'm pretty sure the slot would be damaged when I remove it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You cannot unscrew it to get it out, if you screw it in, does it stop or continue to spin? If it stops, you will need to drill the head off, remove the cover and see what you can do to fix the female receptacle as you are thinking.
Esta resposta foi útil?
Pontuação 1
1 comentário:
It stops but I am scared at the thought of drilling it since I might damage the system.
por
Adicionar a sua resposta
harsh la Rose será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 301
