Ir para o conteúdo principal
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
318 Perguntas Visualizar todos
Kennmore HE4 front loader dryer keeps shutting off mid cycle
Kennmore he4 dryer keeps shutting off mid cycle and wont turn back on unless I reset the braker then it pops up a pf code and I clear it and it will repeat the process it will last 10 to 15 minutes then completely shut off. Weve clea and replace the venting stuff replaced all the fuses. And it still doing the same
Esta é uma boa pergunta?
Pontuação 0
1 comentário
mind repeating the following in English this time "Weve clea and replace the venting stuff replaced all the fuses"? sounds like an over heating issue...are you sure that all debris is has been cleared from along the discharge tube ( that means no blockages clear through to the point where the tube connects to the outside discharge?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Solution 1:
The Circuit Breaker is Weak
Over time, circuit breakers can weaken. If the circuit breaker is weak, it may trip too often, even if the amperage draw is below the limit. If you have already checked all of the potentially defective dryer components, consider having an electrician replace the circuit breaker.
Solution 2:
Heating Element
Sometimes, if the heating element fails, it shorts out against the heater housing, causing the dryer to trip the circuit breaker. To determine if the heating element is at fault, use a multimeter to test each terminal for continuity to the case. If the heating element has continuity to the case, it is shorted out. If the heating element is shorted out, replace it.
Solution 3:
Heating Element Assembly
Sometimes, if the heating element fails, it shorts out against the heater housing, causing the dryer to trip the circuit breaker. To determine if the heating element assembly is shorted out, use a multimeter to test each terminal for continuity to the case. If the heating element assembly has continuity to the case, it is shorted out. If the heating element assembly is shorted out, replace it.
Solution 4:
Drive Motor
Sometimes, when the drive motor fails, it shorts out internally, causing the dryer to trip the circuit breaker. To determine if the drive motor is at fault, use a multimeter to test it for continuity. If the motor windings are shorted out, replace the drive motor.
Solution 5:
Terminal Block
Electric dryer power cords attach to the dryer at a terminal block. If any of the wires on the terminal block are loose, they can arc and destroy part of the block. If this happens, one of the wires can short against the body of the dryer, causing the dryer to trip the breaker. This is not a common occurrence.
Esta resposta foi útil?
Pontuação 1
Power off and Unplug unit. Remove Cover where Eletrical Switches and buttons are look for main power supply by following thick black or red wires that lead to a large square or cylinder shaped object that may still hold eletrical charge. Using a gloved and grounded hand and an eletrical test meter test both ends for voltage. If none present remove and replace this object called a CAPACITOR it is not a back to the future joke but an actual important part that acts both as a fuse and regulator for power that comes in from wall plug and supplies the machines motors and components with correct amount of power. If replacing this part doesnt help you may have to give in and call repair man or buy good used one from a friend or neighbor Good luck
Pontuação 0
Adicionar a sua resposta
Kayla g será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 629
