Ir para o conteúdo principal
Lançado em 26 de outubro de 2018. Modelos A1984, A2105, A2106, A2108. Disponível como GSM ou CDMA / eSIM, nano-SIM ou SIM dual / 64, 128 ou 256 GB / Preto, Branco, Azul, Amarelo, Coral ou Vermelho. (Pronuncia-se "iPhone 10 R.")
How to shut off iPhone XR with a broken screen
So I was trying to replace my broken screen, and in the process I accidentally broke it further. No big deal I thought, since i’m replacing it anyway. Then before I got all the adhesive off, I accidentally turned it on. Is there a way to either shut it off without the screen or safely disconnect the battery? Or do I have to wait for the phone to die
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Press vol up, then volume down then press and hold power button.
Do this until you see the screen go off, then on again then off. Usually this makes the phone stay off without itself turning on again.
Esta resposta foi útil?
Pontuação 2
1 comentário:
this dosent work it turns back on in minuntes, esentally restarteding the phone
por
So it’s actually to press up down and hold power button until screen shuts down, and then push up and power together and hold until it shuts down again and there you go!
Pontuação 0
Adicionar a sua resposta
Christian será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 61
Ao todo: 22,761
