I get ink smudged down edge of paper when printing
When printing, there is smudged ink from the cartridge down the edge of the paper every time I print.
Esta é uma boa pergunta?
Hi Mark, what had you tried?
Had you tried checking on the toner?
Do you have a spare toner? If so, install and print again. Observe the results
There are some possible reasons why you are getting this….
Share with you on the links below for an idea:
Esta resposta foi útil?
Just buy “paper path cleaner” sheet and use as directed until prints cleanly
your catriage may be over filled.
your catriage may have encountered problems, may need replacement.
try checking the catriage cleaner to know if it is over soaked then clean it
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 1,759
