Ir para o conteúdo principal
Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
71 Perguntas Visualizar todos
S10 fingerprint scanner - Screen replacement
Hello!
If you are in need of changing screen on Samsung S10.
Will the integrated fingerprint scanner still work?
Or does a original replacement screen got the scanner already installed on the new screen?
Thank you.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Hi MrSir
The S10 screen with frame assembly will have the finger print reader pre-installed. This will be compatible with your board so long as the part is of original quality. I would recommend getting an original Samsung replacement part if possible.
Best of luck!
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Do I have to change my old finger scanner if im changing the screen with a screen that has a finger scanner?
Pontuação 2
1 comentário:
It is a s10e * correction
por
Adicionar a sua resposta
MrSir será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 3,205
