Ir para o conteúdo principal
The Samsung Galaxy S8 Active can be identified by model numbers SM-G892A (AT&T) and SM-G892U (T-Mobile and Sprint) and was released in August 2017. The Samsung Galaxy S8 Active is an Android smartphone produced by Samsung Electronics as the eighth generation of the Samsung Galaxy S series.
25 Perguntas Visualizar todos
Will a S8 fingerprint sensor work on the S8 Active?
I’ve got a S8 Active which fingerprint sensor doesn’t work. Each time i try to load the fingerprint scanner section of the settings I’m greeted with a message that says “Attention: An error has occurred with the fingerprint sensor… restart your device.” I’d like to know if the S8 Active sensor can be replaced with a S8 sensor. Please do not suggest other methods of fixing the Attention message, I’m certain the sensor is destroyed. Thank you!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
I don’t believe they can be used interchangeably. The cables are different lengths so not the same part
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Landon Orr será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 145
