Model 29875GE2-B doesn't answer
Machine does not answer. Have checked all connections. Disconnected power, waited, and reconnected. Re -programed. No joy
Esta é uma boa pergunta?
No expert on these units so the following may or may not be applicable as a solution to your problem. Does your unit have a backup battery (saves settings in case power goes out). If it does, it may need replacing. The user's manual states the the "answerer must be switched on". If the battery does need replacing it could also mean that the settings for the answerer have been toggled off. Just a thought.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 463
