Ir para o conteúdo principal
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
face id disabled by water through the bezel
My phone is having a problem with face ID it said move little lower and it is very frustrating but my proximity sensor, ambient ligth, front speakers and microphone is still working. I don’t think the flood illuminator , infrared camera and dot projector is not working.But when I use protrait mode in front camera it doesn’t change the stage ligth, stage ligth mono others also and when i use animoji it still works. How do i know my known my flood illuminator, infrared camera and dot projector is not working? If I change the flood iluminator will it work? And after trying to add face ID It said face ID is not available try setting up face ID later and I do not see the infrared light coming out from the flood illuminator.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
hi @parimaibam
Can you please tell me if you have fixed this problem?
por
same problem here
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Looks like you can check out the guide here as a reference.
Troubleshooting iPhone X Face ID Not Working 'Move iPhone a Little Lower/Higher'
Good luck bro!
Esta resposta foi útil?
Pontuação 1
If you’ve attempted replacement of the FaceID component, its possible that the secure enclave protection has kicked in. Replace it with the OEM part and continue troubleshooting from there.
Pontuação 0
1 comentário:
Can you further explain it to me ?
por
Adicionar a sua resposta
Parimanja Maibam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 3,405
