MBP Early 2011 charges battery extremely slow
Hello, everybody.
I purchased a second hand MacBook Pro 15" Early 2011 (A1286), everything works properly, except that when I want to charge the battery takes between 8-10 hours to fully charge the battery while I use, I have checked with the program Coconut that I get between 5W-6W of power, I do not know if this will be normal ...
Comment that the battery is third party (Anyoneer) to release, only 2 cycles, not the original Apple, the charger is original 85W MagSafe "L". Is it normal that it takes so long to charge? If not, what do you recommend I do?
Have passed near 7 cycles, and battery takes same time to charge (near 10-12 hours shut down). Any suggest?
Is possible know if is a battery problem, or was a MagSafe charge port failure?
I realized two Apple Hardware Diagnostic (the short and long version) 0 failures.
Thanks for your time and help to all
Esta é uma boa pergunta?
