Where is the fuel pressure sensor located on a 2005 Honda Accord
Where is the fuel tank pressure sensor located on a 2005 Honda Accord ex ? Any videos that are available for this job
Esta é uma boa pergunta?
I do not have an exact location. Based on how the sensor works, it should be located on top of the gas tank, likely at its highest point, or on the side close to the top. Look for a wire connectors or wire harnesses and you should be able to follow them to find the fuel tank pressure sensor. Looking at the part, it may have a vacuum line running to it as well so it could be easy to identify.
Here is a general video you may have already found that gives a basic description as well as methods for testing the sensor for correct operation: https://www.youtube.com/watch?v=TPVBj6gJ...
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,947
