Ir para o conteúdo principal
Static noise when calling
Hi,
So I fixed a water damaged iphone 6s,changed screen, battery, charging port and WiFi antenna and removed a shorted cap, the phone works perfect apart from when I make a call the person on the other end can hear static,
Any ideas would be great.
Thanks
Andy
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
test using voice memos. if you can record voice memos with no static sounding then the mics are okay and the fault likely lies with something in the network capabilities. maybe a new antennae but more likely board damage caused by the water
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Have you tried another earpiece speaker or front camera assembly? If either are liquid damaged that may be causing the problem.
Substituição do conjunto da câmera frontal e sensores do iPhone 6s
Substituição do alto-falante auricular do iPhone 6s
Imagem de iPhone 6s Alto-falante auricular
Guia
Nível de dificuldade:
Moderado
10 - 25 minutes
Imagem de iPhone 6s Conjunto da câmera frontal e sensores
Guia
Moderado
1 - 2 hours
Pontuação 1
2 comentários:
Thanks for your help, I'll give it a go later and let you know.
Andy
por
Hi,
So I removed the front camera and speaker and the static is still there, I did disconnect the charging port and the noise disappeared so I thought was maybe a dodgy port, so tryed another but still the same issue, any more help would be appreciated,
Thanks,
Andy
por
Adicionar a sua resposta
Andy mck será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,233
