Ir para o conteúdo principal
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Perguntas Visualizar todos
Should the fans run all the time on a 820 00239
I got sent a mac which had the U5860 temp sensor torn off along with all the pads on the board. It would take ages to boot if at all and the fans where spinning flat out. I turtled the chip, ran 9 jumpers, masked the chip and jumpers and installed the board back into its housing. I have tried all the resets.
·         The mac boots straight up but the fans do not spin
·         When I run the diagnostic check it will spin each fan separately
·         The diagnostic results show no problems detected.
We live in a cold climate I have tried playing YouTube videos to get the fans to spin but they don’t. The CPU doesn’t feel extremely hot. Am I missing something or is it normal on these newer macs?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Unless you are located on Antarctica right now, your not is a cold enough climate to worry about SMC and the thermal sensors ;-}
What does TG Pro tell you? Post a snapshot of the main window (you'll need to resize it to get everything in) Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks Dan. TG-PRO displayed a message saying. “This model of mac will safely turn the fans off when the CPU is running at low capacity.” That’s all I wanted to know.
por
@imicrosoldering - Thats good! Sounds like you good to go! Don't forget to accept the answer.
por
Adicionar a sua resposta
Chris Stables será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 270
