motor diesel da d20
Lynn Reilly @lynnreilly
Rep: 1
Postado: 30 de ago de 2019
My power window is stuck down how do I manually get it up
Esta é uma boa pergunta?
4 comentários:
Checked fuses for a start?
30 de ago de 2019 por prop man
Switch might be dirty or sticky, try wiggle a lot to see if intermittent. Otherwise try to pull window it up or slam the door , both while holding the button in up position with car ignition on.
30 de ago de 2019 por uhf mhz
Another think to check is for a broken wire near door hinge where wires go from car into the door.
Lynn Reilly what exact year and model is your PU?
30 de ago de 2019 por oldturkey03
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 23
por prop man
por uhf mhz
por uhf mhz
por oldturkey03
