Ir para o conteúdo principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Screen flickering when phone is turned on
My htc one m7 fell into water and screen flickers every time i turn it on
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Water damage is never good. It is best to immediately open the device and dry thoroughly when it has come into contact with water. Otherwise, the water can create many shorts and destroy components quickly or it can leave mineral deposits and create corrosion over time.
The water could have made its way into the display, the display connector, or a component on the logic board responsible for display, display output or backlight. It may be best to get it to a professional for proper diagnosis.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Seth Abankwa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 123
