Ir para o conteúdo principal
The Hover-1 Coast (HY- SRMT) model number: CP2910, is an electric remote controlled youth skateboard that was released in 2018.
Why is my LiftBoard showing blinking red light when turned on?
I have a dual motor lift-board. I’ve had it for a while now but it’s been a since I’ve ridden it. It was good when I was using it. Now I’m trying to start using the board again and it won’t charge. The light keeps blinking red and I don’t know what to do. How do I fix this problem and if I can’t fix it can y’all fix it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Is there a pattern to the blinking? How long has it been plugged in?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Battery could have discharged too far. Recommendation is to get the wheels spinning for 10-15 minutes (they even go as far as saying to be pulled behind on bike) at roughly 10MPH. Check your remote to ensure it gets a little bit of a charge then try charging again.
I'm not sure what type of batteries these run but if they are LiPo, if not stored properly it can cause issues.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jay-U Kamara será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 2,480
