Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Can I get a custom serial number on a MacBook bottom case replacement?
I’m working on a MacBook Pro. The bottom case is damaged so I want to replace it. However, I want the serial number on the bottom case to match the Mac’s serial number. Is it possible to get a custom or no serial number on an iFixit or any other bottom case replacement?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I’ve never seen anyone offering the serial number engraving service. Most bottom cases around in the market are usually used replacements with the original serial. You can try reverting to chinese sellers, although I doubt it would be economically interesting even for them to offer such service and in the end you would probably see the number has been forged anyways.
Esta resposta foi útil?
Pontuação 3
When Apple or an ASP exchanges a bottom cover, they write the original serial number on the inside of the cover with a large black marker.
Pontuação 3
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 798
