Ir para o conteúdo principal
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Perguntas Visualizar todos
Superdrive replacement
Hi!
I'm having trouble with my Superdrive Pioneer DVR-K06 and need to replace it.
Jason, you wrote that you have replaced it with a Matshita Blue-Ray, how did you do it? I'm very interested in if it is possible to replace the superdrive with any slim DVD/BR device?
I'm in desperate need for help, I have a stuck CD in the superdrive and it keeps trying to eject it, unsuccessfully!
Esta é uma boa pergunta?
Pontuação 2
1 comentário
If you still have the stuck disc problem: • try to eject while in Toast Titanium 9 (or newer). It has an eject option which has proven very useful for me in the past when I have had the same problem. • hold down the mouse button on restart until the disc ejects. • drag the disc icon to the trash • try eject from iTunes • Open Terminal and type "drutil tray eject" to eject the disc/tray • Good luck. I hope this helps.
por
Adicionar um comentário
1 resposta
Solução escolhida
I replaced it with the help of this guide. It was a little bit tricky but easy overall. Patience is necessary.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Jonas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 832
