Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
20 Perguntas Visualizar todos
White screen of death, otherwise fully functional
HI peeps, i realised my home button was not sensitive so i went on to pry open my whole iphone and wanted to adjust the pins connecting to the home button. but i broke them
-.- as i attempted to replace those pins with aluminium foil, i accidentally dislodged the screen from the motherboard. after which i reconnected cables 1 2 and 3, and everything went back to normal. But the cables became loose and kept falling. when i reconnected them again, my lcd screen would be white when i clicked the sleep/power button , vice versa would turn black when i press the sleep button when the screen is white. everything is functional (except for home button), i ca on/off it tho the screen is always white, i can fel the vibration when i switch the silent mode little knob thingy. the only thing is that the screen is white! help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
if you are happy that the cables are connected then you need to do a hard reset. your poor phone just needs a good kickstart hopefully. hold home and power together for 10 seconds, the apple should appear, release the buttons and allow to reboot.
Esta resposta foi útil?
Pontuação 2
2 comentários:
my home button is not working
por
try holding power for 10 seconds and then sliding finger across top of screen as if "slide to power off". this may do the trick..
por
dfu mode then do a restore through itunes
Pontuação 0
How would I repair my phone if the phone is fully functional, but its just a white screen and I can’t see the front icons. The front screen glass is completely cracked too. Can someone help?
Pontuação 0
Adicionar a sua resposta
shawn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 645
