Ir para o conteúdo principal
I changed a battery for a customer. screen touches by itself.
So I replaced a battery for a client of mine.
after that she came back (after about 3 weeks). The screen clicks by itself.
From what I know a battery replacement should not do this to a phone, anyone know of a solution?
I did replace the battery three days ago again, since I thought maybe there was a bad battery, she came back now. Same issue.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I believe that would be a bad digitizer module or connection. Try reconnecting the display, then switching displays (if you have a spare).
An iPad I once fixed was worse. When you had the keyboard up it would type random things, even when you leave it alone in a room with no one else. It was like a ghost possessed it.
Good luck!
Esta resposta foi útil?
Pontuação 1
1 comentário:
I have a battery stand, the customer said she changed screen at someones home before that, so it was solved with a new screen.
por
Adicionar a sua resposta
nicolay.94 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 44
