Ir para o conteúdo principal
My phone wont turn on
First my phone start to stuck then the problem develop when it stuck then it goes to black screen i watched YouTube videos how to fix so i open it disconnect battery home button touch screen and display connector after few minutes i reconnect all connector but this time when i want to turn it on it just shows a logo then it turned itself off.. up to now it doesn't turn on even i put on charger
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I have an iPhone 6 plus to and it is very important that when you are reconnecting the connectors the you do the battery LAST because you can accidentally fry the screen if you connect the battery first. I had the same problem when I fixed an iPad I had accidentally fried the screen because the battery connector was touching. I recommend for you that you get a new screen and use the repair guide on ifixit.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Magdalena Mang'ong'o será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 28
