Ir para o conteúdo principal
Repair guides and support for a wide range of small engines.
Briggs and Stratton over revving
Briggs and Stratton over revving model 125k02-0389-e1. It’s over revving, can’t seem to find the problem. I have changed the carb out. Also the governor spring and air vane spring. I have moved the governor back and forth that does nothing. I can choke it up with the air vane spring.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
What's the idle screw at (If it's anything like a car carburetor)?
Could also be compression, timing, or misaligned/disconnected throttle plate.
I'm more of a car person, so please tell me if these parts don't exist on the engine!
Good Luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Willie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 759
