3DS wont turn on after turning up brightness
The 3D function wasn’t working previously the system would shut off. Turned up the brightness on the bottom screen from 1 to 3 and it wont longer turn on. System turns on for a second and makes a pooping sound then turns off.
Esta é uma boa pergunta?
Pontuação
0
Hate when electronic devices make "pooping" sounds! lol Turning up brightness draws more current from power supply/battery. Probably wouldn't be a bad idea to open up unit for visual inspection. Look for bulging capacitors, cracked or cold solder joints, heat marks etc. Clean and reseat connectors, bulging battery etc.
por prop man
