Ir para o conteúdo principal
Guias de reparo, informações de desmontagem e resolução de problemas para a terceira geração do Apple iPad com Wi-Fi, disponível com 16, 32 ou 64 GB de armazenamento. Lançado em março de 2012. Identificado pelo número de modelo A1416. Os reparos exigem o uso de calor e alavancagem cuidadosa.
Punctured battery while replacing, help
As I was replacing the battery on my iPad 3 I accidentally punctured the battery and I have now (as of the time I am posting this) gone two days ago without touching the battery and leaving it in a place where it won’t catch fire. Is there anything I can do to take out the battery safely? It is also important to not that I took out the logic board and I was planning on replacing the battery anyways. The battery did also smoke up the first time and when I tried removing it more it caught fire. If I go back will it explode or am I safe?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Phone local fire department for advice?
por
Adicionar um comentário
3 respostas
Found another user who had the same problem: maybe try, with your phone ready to call 911 at any moment?
Battery punctured while removing (small flames) Still need to remove
Esta resposta foi útil?
Pontuação 0
These batteries tend to flame and smoke when the plates touch. I have never heard of one exploding yet.
Always keep yourself safe with Li-Ion batteries. They are evil.
I doubt a repair shop will touch it.
I would go outside and do it.
Disconnect the battery making sure it is not glued to the shell and launch it.
If it flames out, no biggy. Now connect your new one.
Pontuação 0
My power bank is not working
Update (11/07/24)
Pontuação 0
Adicionar a sua resposta
johndiaz693 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Ao todo: 555
