Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
No camera functions working
So my colleague replaced the back cover and screen for an iPhone X. By replacing the back cover i mean that we bought a new frame with the back cover already in place. After the replacement the main camera no longer works and the front camera only works sometimes.
I have tried the following:
- Replaced the main camera.
- Replaced the front camera.
- Replaced the flash and on/off button cable.
- Replaced the bluetooth antenna cable.
- Checked all the connectors on the main board and all look fine.
- Did a full reset of the phone 2 times.
All this and nothing worked. I tried turning on the flashlight as well but nothing happened. Any idea what it could be and what to try next?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
I’ve seen this a couple times on an iPhone X, and it seems to be a board defect. When you say you tested the board connectors, did you test voltage on the pins specifically?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you for your answer.
So if it's a board defect it means my colleague didn't cause it and it was a coincidence? I mean it's not exactly easy to damage the board by removing it from the case. The iPhone X board don't really have a lot of exposed components.
Never said i testet the board, i just visually checked the connectors. Maybe i should have been more clear about what i meant. Whats the best way to test the voltage? Is there a tool i can use or a multimeter will do?
por
Try to put it back in the original back case and when it works you know it is a fault in back case that you bought.
Pontuação 0
1 comentário:
Already have. Same result unfortunately.
por
Adicionar a sua resposta
Total Repairs AS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 159
