Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
Will not power up
I replaced the display and home button would not respond.it was like it was always working. iPhone would not power down and when I opened it up and unhooked the cable the power was on.now it will not power up did I short out the logic board?
Update (08/21/2019)
i believe you are correct on short.it connects to iTunes with info about device just no display to see.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
when you say unhooked the cable, do you mean the display cables?
you may have shorted out the logic board, at least the display portion of it. always recommend disconnecting battery as soon as you can on any electronic device.
you can try hooking it up to itunes and do a restore, though it’s unlikely to work. at the last if it connects to the device then you know the device turns on, just no display on it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Marcos Polos será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 37
