Ir para o conteúdo principal
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 Perguntas Visualizar todos
iPad Air 1 home button pad missing
I have ordered a replacement home button for the iPad Air 1, but upon receiving it, i noticed the small central pad in the middle of the button is missing from the replacement part. This pad is the part that pushes on the actual switch. The first picture is the button I received and the second is the one in the ifixit page showing the pad I’m talking about. Is my button defective or Am I missing something when ordering replacement parts? I appreciate any help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
As long as the button you received can actuate a click of the home button you should be good to go. If not, try to find another seller with a higher quality part.
Esta resposta foi útil?
Pontuação 0
2 comentários:
If not the middle of the black metal bracket that sits behind the home button can be bent inwards to get it to click sometimes.
por
Thanks, I have ordered the replacement button from 2 different sellers and none of them have the central pad. It turns out the button does not actuate the switch in this condition.
por
Adicionar a sua resposta
Rodolfo Granados será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 91
