Ir para o conteúdo principal
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
Power Button does not click after re-assembly
After putting the top on, the power button doesn’t click. It clicks fine until i clamp all the plastic clips around it in. Screwing it in or anything like that does not help either. Nothing seems to be in the way of the button either
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Just a thought. If switch uses mounting screws, maybe try putting some plastic washers between the heads and the computers frame to see if that makes a difference. My stance for my own personal equipment, if a solution works, it works and that is good enough for me. :-)
por
Adicionar um comentário
1 resposta
Try reseating the ribbon cable that goes to the buttons. Most likely it's slightly out of position or something.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Thomas MacGregor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 131
