Ir para o conteúdo principal
Released 2016, this Sharper Image stunt drone is rechargeable and has a 150-foot flying range. It is black with 4 propellers. It has a 2.4GHz transmitter. It requires no FAA registration and includes charging cable and (4)replacement blades. It has removable blade guards.
How to center the drone with the direction trim
hi name is jack and i bought a sharper image drone and the drone will not center like it is suppose to
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Without either gps, optical or pressure sensors stable hovering is not possible. Trim adjustment is used to reduce drift. Look into all the forces acting on these quads and you will see how amazing it is they can even fly! Happy Hovering!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jack spriggs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 471
