upgrade mSATA to NVMe
Hi,
I have 2 questions:
Currently i have MacBook Pro 13“ retina late 2012 A1425
My current SSD is Feather P12 with max speed is 450 mbps, I’m looking to upgrade it to NVMe SSD with high speed 1000+ mbps.
- I tried to find a converter from NVMe to 7+17 pin SSD but did not find any adapter that supporting my request, they told me since it is SATA the max speed is 500 mbps, in my System Report, showing NVMe but not installed, is it possible to add a NVMe supporting SSD ?
- If the above question was answered with no, not possible. Can I upgrade my logic board with newer version like late 2013 retina that supports NVMe? If yes, what else do I need to replace?
Thank you very much, regards
Update (08/10/2019)
hi dan
the current one is 6GBps , check attached screenshot , as you can see there is also nvme express but it is not exist
Esta é uma boa pergunta?
5 comentários
Take the time to review this great write up The Ultimate Guide to Apple’s Proprietary SSDs
por Dan
hi dan , that did not answer my question actually i understand them but not sure how to hack it
por Maen Abu-Tabanjeh
@jordannet - Sadly you can't do what you want to do here.
The hardware review lists a lot of things that your system doesn't have so don't assume that because its listed the system has the ability it just doesn't.
por Dan
@jordannet Have you solved the problem? I am looking for the same adapter.
por luca.dalessandro89
@luca.dalessandro89 - There is no problem here! Just an expectation the system has the ability to support something it doesn't.
I've added a graphic to my answer which I think helps clarify things a bit.
por Dan
