Ir para o conteúdo principal
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
20 Perguntas Visualizar todos
Why won’t my laptop charge?
My laptop shut down (low battery) and when I try to charge it (tried to wait for 30 min) it only shows the low battery screen with the connect to power symbol. Charger kept sparkling when put into socket, plastic not melted but metal prongs slightly melted (edge part a bit rough). Is the problem with my charger?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Are you using the original charger and USB-C cable that came with your system?
por
Adicionar um comentário
1 resposta
Hello,
I’d advice you to try to use a different charger and see what happens. Meanwhile, try to move the charger adapter around and see if it starts to charge it. If you get the computer to start charging try to do SMC reset and PRAM reset and let us know what happens.
Cheers!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
bianca será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 87
