Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Perguntas Visualizar todos
My motherboard is bad. How can I see what processor and ram it has?
Hello, I have a Macbook Air 13 inch early 2015, and the computer does not power on, as it has water damage on the board. I am looking to purchase either an identical replacement board, or an identical replacement Mac and transfer over the SSD. My problem is that I’m not exactly sure if the board is an i5 or an i7 processor, or whether its 4gb or 8gb RAM. Is there any way I could find out this info from the board? Any help would be appreciated. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The board reference just gives general info about the Mac but it doesn’t tell if it’s an i5 or i7 nor any RAM specs. If the bottom cover has never been replaced you will find printed there the serial number that you can insert in this database search for further details: appleserialnumberinfo.com
Esta resposta foi útil?
Pontuação 2
Look on the back of the machine and find the serial number.
Plug it in here and it will tell you exactly what it shipped with.
https://everymac.com/ultimate-mac-lookup...
Pontuação 2
Adicionar a sua resposta
Armen Orbelyan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 394
