Ir para o conteúdo principal
Repair guides and support for Digital SLR cameras by Nikon from the high-end professional range to the entry level consumer cameras.
624 Perguntas Visualizar todos
eyepeice panel replacement Nikon D850
Hi, the eyepeice panel part number 125SR-A05L9Y is cracked on my D850 and I have purchased a replacement panel. There are two external screws at the top corners. Removing these does not release the panel. What further steps do I need to take to remove and replace this panel.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Looks to me like it might be attached to the top panel by a screw on the inside, so need to tear it down a bit more.
The steps are likely to be similar to the D500 that I had to open up.
I’m linking my guide below.
Nikon D500 Top Panel Removal
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Andy Jones será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 187
